Clears the LLDP neighbor information collected for one or all ports on the switch.
| port_list | Specifies one or more ports or slots and ports. |
N/A.
LLDP neighbor information for each port is automatically cleared after the period defined by the TTL TLV if no update LLDP protocol data unit (LLDPDU) is received. This command immediately clears the LLDP neighbor information for the specified ports.
The following command clears the LLDP information collected for all ports on the switch:
clear lldp neighbors all
This command was first available in ExtremeXOS 12.4.4.
